ctlogistics
- Joined
- Jan 18, 2015
- Posts
- 6
- Reaction score
- 0
2003 Tahoe 5.3 Flex 201000 miles
Having a hard time starting my Tahoe. It will crank and then fire up enough to disengage the starter, then dies. If I leave the key in the 'on' position for about ten seconds it will start on the second or third try. I already replaced the fuel pressure regulator and that seemed to make it worse. One more thing I noticed, when it does start there is a strong odor of gasoline. However, I don't see any leaking of fuel anywhere.
Update: This morning it wouldn't start at all, just crank. The fuel gauge read a little less than half. I added about three gallons and it fired up on the second try. (It never starts on the first attempt.) Got a fuel pressure gauge at Autozone and hooked it up. First read with vehicle on, but not running was just under 10psi. While running it stuck right at 38psi - no variance. Shut it off and released the pressure and turned back to the 'on' position - 0psi. No matter how many times I tried 0psi in the on position. It would still start and read 38 while running, but nothing when just turned on.
Thanks for any help,
JT
JT
