Good Deal Spotters' Thread
adriver
Yeah, I would go pick it up right now just for the hell of it for $500. The no title is too sketchy for me.. Legally I'm pretty sure a buyer would need a bill of sale. If its been sitting on the shop he supposedly just bought, he should learn that you apply for a lien title to take possession of it after 30 days. Its a few hundred bucks and then sell it for a few thousand easy... Not sure what his business motto is going to be, but I don't think he is going to do well if that story is true. I would put a lien on it. After you take possession, you fix it and sell it if somehow he knows it was running...
adriver
https://inlandempire.craigslist.org/cto/d/perris-1994-yukon/6800748847.html
1994 Yukon - $3000 (perris california)
THREE 2 DOOR YUKONS FOR 3k. (POSTED 23 MINUTES AGO).. .. IF.. IF.. This is legit WOW!!! (WILL GO QUICK)
Three 1994 GMC Yukon. The grey one's motor does not work. The black one and the white one run well. I am asking for $3000 for all three. If you have any questions please call rather than text. Please come look at the car before making an offer as my views may be different than yours.
adriver
Taking that down... Don't want you sniping me, Ill post it later.. :sorry:
adriver
NO CLUE if this is a good deal, what else is needed, if its possible to add, the condition.. NOT AFFILIATED....
QUADRASTEER REAR AXLE - $250
COMPETE REAR AXLE / 4.10 GEAR RATIO
WITHOUT STEERING SENSOR OR RACK AND PINION
ITS OUT OF 04 GMC SIERRA DENALI 1500
ON THE GROUND READY TO GO
https://tucson.craigslist.org/pts/d/tucson-quadrasteer-rear-axle/6782826028.html
Twin turbo L96 (6.0 LS) - $1800
2011 L96 70k miles
Forward facing turbo manifolds
Twin 70mm GT3582 turbos
823 square port heads
I have a LS3 intake as well
58lbs injectors
E85 compatible
No wiring harness
No ECU
Needs head gaskets (not blown)
I've never had it running due to lack of money but it came out of a 2011 Silverado 2500HD
https://yuma.craigslist.org/pts/d/yuma-twin-turbo-l96-60-ls/6805073007.html
adriver
I know this isn't anything too similar, but this is definitely a nice project for someone.. (54, 5 window, manual shift, AZ 71K mile driver.)
1954 GMC 100 truck 1/2 ton 5 window runs trades ? Drive it home - $5000 (PHX Chino valley)
1954 GMC truck 1/2 ton 5 window straight 6 manual shift
Clean AZ title Arizona truck has Vin tag matching Numbers
Original engine 71 k stick shift cluch good lights work
Has heater works 5000 $ obo trades welcome cbr Jeep Wrangler Harley Chevy Silverado Short bed Travel Trailer show contact info cheapest one in Az with title notarized ready to go show contact info Drive it home
(most posts get 1 picture, some times they are nice enough for 2 pics, this survivor deserves 3).
https://phoenix.craigslist.org/nph/cto/d/phoenix-1954-gmc-100-truck-1-2-ton-5/6807510628.html
Pretty cool.
adriver
1972 Chevy Real Shortbox on AWD Escalade frame Badass Project LS 6.0 - $4500
https://phoenix.craigslist.org/wvl/cto/d/sun-city-1972-chevy-real-shortbox-on/6811160356.html
Super cool project, we just don't have time to do it right now and making some space in the yard so testing the waters. Have a truck that started with a 72 chevy cheyenne cab with all the factory holes for headliner, cargo lamp, and uncut dash. Got the rest of the body from a actual short box, not a cut down box, solid factory GM bed sides. Then the truck has been mocked up on a 2002 escalade frame that is complete rolling All wheel drive chassis setup for 6.0 from factory but use any LS that is virtually same wheelbase as a factory short bed frame from 72. Now you have a badass AWD 72 with 4 wheel disc brakes already. Selling the complete rolling Body shell for $4,500 cash. Its a complete custom put together truck so it will need to be brought down to DMV and have a AZ assigned vin, basically making a hot rod. I do have LS motors available for different prices. also have a buildable 4L70E from the escalade, no transfer cases though. Let me know. its a complete project, I even have a 72 long bed frame that i will throw in with the purchase so you have all the mounts to get the body mounted to this frame, only need to cut the front ends off the escalade frame now so you can get the front bumper back where it should be sitting close to grille and fenders. text or call 612 29six 92 3 six thanks for looking and god bless.
adriver
2000 Chevrolet Tahoe Z71 4X4 6,100 orig mi, absolutely NEW , pristine cond
Vehicle is 100% original including the tires. They do have slight dry rot cracks due to there age but the thread is like new. I didn't want to replace the original tires as it adds to its authenticity.
(Definitely extremely clean, but its got rust underneath, and all that rubber should probably be replaced... I'm AMAZED, THAT its up to US $18,700.00, with 16hrs left, 23 bids, and Reserve not met... WOW... )
eBay item number: 292935285291
https://www.ebay.com/itm/292935285291?_trksid=p11021.c100851.m5053&_trkparms=aid=222007&algo=SIM.MBE&ao=1&asc=20170803121420&meid=8fff127053aa474aae148493db9087e4&pid=100851&rk=4&rkt=4&mehot=pp&b=1&sd=223367877051&itm=292935285291&ul_noapp=true
db487648
