Getting rid of T55 caliper bolts
06Escalade
I wanted to get rid of the T55 Torx bolt so I purchased replacement caliper bolts from AZ. I did not put them in because they were slightly longer. Is that ok? If so, do I need to replace the rubber insert?
The hex head one is not only longer, but appears to be wider and with a different thread pitch like it's a slide pin from a larger vehicle or at least one with larger brakes. Is it one from a 2007+?
06Escalade
06Escalade
Its listed as 06 Escalade front. H15086. Here's another view. Its close but still, longer. Is that on purpose, or should it be exact?
Must've been the angle and lighting cuz now the new one looks smaller.
If the only real difference is the smallest diameter portion at the tip of the pin being longer, then this is insignificant. It'll just stick out of the hole in the caliper that much more. The portion following that is what actually locates the caliper and is where the caliper slides. That's the part I'd be concerned about. Screw one in at the top or bottom hole of the bracket and one of the originals in the other hole without the caliper in place and see how they compare. If the new one fully seats just the same as the original, then you should be good to go. The rubber boots don't have to be replaced it they're not worn or damaged.
golavaman
