Factory Style Fender Flares
Madgrty
St. Louis MO
Does anyone know anything about the OE-Style Fenderflares? I'm really liking this look and debating on buying a set. Just wanted some input first.
Madgrty
Madgrty
St. Louis MO
I would be painting them white, the same color as my Yukon and ironically same that's in the picture. Curious as to how the bolt on, how do they hold up, are the aftermarket ones smooth like in this picture or textured.
MadDogDelpho
Texcellent
Texas
I think some may be textured but it's not too difficult to paint match them. And I'm fairly sure they bolt into existing holes in the fenderwell, with the rear door parts being attached with double-sided tape.
05Single
afraid of the dark
Don't bolt on. They use push pins. Double sided tape on the rear doors like @MadDogDelpho said.
I have oem textured black but plan to smooth and paint. Gonna have popeye arms after I'm done sanding lol.
Communicate with the seller and double check to make sure they're smooth or textured.
Madgrty
Madgrty
St. Louis MO
I'll have to double check with them, thanks! The only other thing I'm curious about is how far do they stick out from the factory fender?
kwOH
Banned
Only the actual oem ones that came on them from the factory use the push pins around the lip of the fenders, any aftermarket ones that are "OE style" have to have new mounting holes drilled and screwed on. Ive been on the search also man.
Sent from iPhone 7 plus using Tapatalk Pro
Madgrty
Madgrty
St. Louis MO
And drilling an screwing is nothing bad, do you know if it still lines up with the holes that are already along the inner fender or do you have to drill through the side (exterior)
Pepper1700
