Exhaust Flange Gasket
RAWVORTEC
Lburg
2003 Yukon Xl 5.3. I have a leak in front drivers side where flange connects. I can't seem to find it online. Can someone send a link of the correct flange?
last time I had to do mine I just went to the junkyard and sawed one off, mine was warped and no way to stop it from leaking
He said gasket in the thread title so that was what I linked. But yes if it's the flange itself that's needed then a junkyard would be the only way fo sho.
RAWVORTEC
RAWVORTEC
Lburg
It's the donut shaped gasket, but everywhere I had seen an example, it was referred to as a flange gasket. In the link you sent, the right and left are different. Is that correct?
That’s what I see from the pictures. I have longtubes on a 6.0 so mines different but on yours it looks like one is smaller than the other.
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
GM# 15035747 RHD EXHAUST SEAL DOUGHNUT $18.56
GM# 15077362 LHD EXHAUST SEAL RING $16.70
RAWVORTEC
RAWVORTEC
Lburg
Thank you guys! Just wanted to make sure that I was buying the right sized one since they're both different
Tonyv__
Bucks county PA
Do you know if there is a gasket that connects from Y pipe to the muffler pipe? I’m dealing with a 2003 avalanche z71 with 5.3. These gaskets seem to match up with the manifold side
waiteben84
