ELECTRONIC HELP NEEDED
mikemhp
2004 yukon 5.3 slt 144k miles.....
had a no start/no crank issue last week... pulled starter and had tested- passes with flying colors.
checked voltage on battery- read 6.2. replaced with brand new one... 12.4 volts
replaced ground cable from battery
cleaned all electrical contacts and grounds
checked all fuses and relays- all good
replaced ignition switch under steering wheel
still getting no crank/no start
saw several posts talking about 'resetting alarm lockout' .... tried a few, but no dice as of yet.
anyone have similar problems or a new way to reset the PCM????
thank you!!!!
mikemhp
mikemhp
got it going.... turns out the 40amp ignition A fuse had a tiny break in the copper ring, but couldn't see it until i actually took the little plastic window off of it.. it was dirty on the underside.
starts strong now, but during test drive, headlights started flickering, and now turn signals don't work..
i think i have gremlins in the fuses... sounds like another short somewhere
BWASTEEZE
