Eibach 2/3 Drop Kit - Install Write-Up (56k Warning)
vjr021
vjr021
Clearwater, FL
Will this be the way for a 2006 yukon xl 4dr? Also is it the same for a lower drop?
It should be the same... If you want to go lower, you will have to add spindles, not covered here. Also likely in the rear a notch, also not covered here.
TailHook
Tattooed Millionaire
Arizona
I also installed a set of belltech Shock Extenders...
Very nice write-up...
...I have the same kit on my Denali, but did not install the extenders. Did you use Belltech #6651 or different? Wondering if installing a set would reduce some of the the tail bounce...
vjr021
vjr021
Clearwater, FL
I think they are belltech... I bought them off a guy here on the forum, pre-owned... From what I hear it will help....
My next mods are the Belltech airshocks and the panhard bar...
TailHook
Arizona
Fair enough...thanks!
Belltech site lists #6651 as the correct part, however most sites (Summit, Stylin' Trucks) state "this part is not compatible with your 2005 Yukon Denali"...thinking the manufacturer knows best what fits!
mag99
I have this kit and the shock extenders. For some reason the instructions with the kit didn't have anything about how to change the keys. That part is pretty straight forward, but my question is...the front rubber snubbers..the truck rides on them stock, so do you remove them entirely, or just cut them down some?? thanks..
Skitch2003
jax fla
how is the ride? I am considering doing either this kit or the djm 2/3 kit with the 2 inch drop keys and springs with the eibach swaybars. been told the ride quality will be bad.
TiGrayMSM
