vtx1800sba
It's been a while since I've been in the forum guys, but have a lingering issue with my 96 2dr. tahoe. If you recall I replaced the shocks, and sway bar links after noticing a clunk in the front end near the driver side. The links needed replacing anyway as one was broke off.
Today my business partner's shop mechanic and I replaced the pitman arm and idler arm WE had it up on the neighbor's hoist a month ago and discovered that both had quite a bit of play and needed to be replaced. Thought that would also cure the clunk.
Well nope it didn't. Still have a clunking noise. It sounds like the driver side up front. I've checked all body parts, mud flaps. The mechanic spun all around the front end on his creeper, and we can't figure it out. I put brand new Bilstein HDs, on it around Thanksgiving. I am suspicious of the new shock up front (driver side).
Also, the steering wheel is not centered since we put the new pitman and idler arms on this morning. Bout a 1/4 plus turn to the right is necessary to keep the truck straight and true. Don't think I need to pull the pitman or idler to fix that though do i?
Please advise.
Please advise.
