Does 2008 Tahoe LT have active fuel management?
pacem
Does 2008 LT have AFM? 5.3L
there is no sticker on the outside of the car, I thought it was supposed to be there.
Is this a bug or a feature?
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Through a tune or look up Range device. Plugs into your dlc and you leave it plugged in. As long as it's installed, it will disable the Afm feature
Kenny D
Crosby, Tx
Range device is the cheapest temporary way to disable. Hand held tuners will do the same at an added cost for the tuner device, but you get a tune out of the deal also. Both can be reversed if you want to go back to stock.
P
pacem
Is there some software I can load on my laptop and connect to the OBD interface?
And a pre-set tune for that model. More aggressive shift points maybe.
I have GU6 rear ratio so it's OK but not a 3.73 type performance.
sumo
rhode island
No. You'll need a tuner but if you want something that will make your truck come alive, I suggest Blackbear otherwise it's going to be a handheld generic tuner that probably won't give you what your looking for
DarkHearse
