Djm control arm issue
Lit549
Has anyone else run these? I have the Djm uca/lca setup,{3"}..I recently installefd the upper control arms to get a better ball joint angle..I also installed the recommended cam locking plates..I had front end aligned,guy said everything was in spec,BUT i clearly see negative camber..I looked at plates and evrything looks maxed out on adjustment..Again,the truck is only a 3" drop with 17s..Its a 2005 tahoe 2wd..
juniordaboi909
