Delete AFM
bad_idea
I have a 2018 Yukon XL Denali with the 6.2l. I recently purchased it and am new to the platform. I have read the AFM system is problematic and is best to delete it. There is nothing wrong with the vehicle currently. Can I get one of those tuners that turns it off and call it good? Or do I need to pull out the AFM lifters and associated bits? I would like a hand held tuner that I can plug in, make the changes, and unplug it. I will use the truck for hauling a trailer on road trips, so if the tuner has functionality to improve towing that would be a plus. Thanks for the help all.
MobileHomie
The simple answer is yes, you can buy a dongle that plugs into the diagnostic port under the dash and disable cylinder deactivation.
I did this in 2020 when I bought my '17 Yukon used with 32,000 miles.
The real answer is in order to completely delete the DOD, VVT is to change camshaft, lifters and a laundry list of other parts including oil pump, to make it all work, followed by a tune.
I just dropped my Yukon Denali off yesterday to a performance shop to have this done.
There are DIY guys out there that may be able to help more.
B-train
I put a RANGE Device in my 2017 Denali when it was 2 years old at 40k. Now has 130k and has been great. Keep your oil clean as well. 5k or less with 5w-30 is what I use. I speculate that the thinner oil used to make better CAFE numbers isn't really all that great in the long run.
Geotrash
Dave
Richmond, VA
I did a mechanical AFM delete on my 2012 and took advantage of the opportunity to put a slightly bigger cam in it worth around 50hp and tq for better towing performance. It's made a huge difference in how much I enjoy driving the truck. Parts cost was around $1500. If/when I buy a newer rig, I will do the same thing again.
Midwest
Curious if you'd be able to share what it cost you to have a shop do the mechanical side of the delete?
MobileHomie
I had the work done at a performance shop. Stage 1 BTR camshaft, springs, lifters, oil pump and a list of smaller items were replaced. All told just over $6,000 for parts and labor. They removed the engine from the vehicle, the tune was done on a dyno.
natureclone
Which cam did you use? Did it require a tune?
Geotrash
Dave
Richmond, VA
And yes, it did require a tune. I used Blackbear. I used their device to log a specified drive cycle before I did the work, then sent them the cam specs. They sent me back a tune that would get me up and running, and then I used their device to log a new drive cycle and they sent me back the finished/complete tune for the cam.
natureclone
Thanks for that info!
rick9667
