2015 AFM Hard Delete Questions
L8T BURB
Kentucky
Hello all! I am on the verge of doing a hard/full AFM delete on my 2015 Suburban 5.3, 2WD with 186k miles. I know this topic has been discussed at great lengths on the forum, as I have found through the search function. However I am hoping to get some insight into my specific situation.
My repair guy said that he will be doing a "motor out" repair on this. He will be taking the heads to a local machine shop to be freshened up. I am wanting to touch every part of this engine while it is out.
Here is what I have so far on the replacement list.
Non-AFM cam (likely BTR)
LS7 style lifters (All 16)
Valve Springs
Push Rods
Non-AFM Lifter Trays
Oil pump
Oil pickup tube
All associated seals/gaskets (Head, valve cover, front crankshaft, rear crankshaft, timing cover, etc)
All intake/exhaust valves
Am I missing anything here? Should I do the timing chain set while there as well? Engine mounts? Anything on the front engine accessory drive? Water pump and thermostat were replaced 6 weeks ago. I know this will be a costly repair, so I am taking the approach of "buy once, cry once" by making sure I replace anything mildly reasonable while the engine is out.
Thank you all!
wjburken
Eastern Iowa
Valve Springs
Push Rods
Oil pump
Oil pickup tube
Thank you all!
Not familiar with this year of vehicle, but might consider timing chain and tensioner.
I would only use GM OEM lifter trays if at all possible. Some folks have had lifters turn in non-OEM trays.
Bigkevschopshop
Northside H-Town
Valve Springs
Push Rods
Oil pump
Oil pickup tube
Thank you all!
I would do motor mounts etc also while its out, possibly look into replacing the injectors since ya will be that far into things.
Thekenstar
