Can door panel be removed with door closed?
paulyt
Hello,
So I recently replaced the passenger rear exterior door handle on my 2007 Yukon Denali. I have replaced at least 3 of my exterior door handles over the past several years and have never had a problem. However, this time the door operated fine for a few days but now it won't open from the inside or outside. Is there a way to remove the door panel with the door closed? I would really appreciate any help or ideas.
What I think happened is when I replaced the door handle and clipped the door lock rod back into place it weakened the clip, and I think that yellow clip that holds the threads of the rod has now opened which is preventing me from opening the door. Any help would be much appreciated!
Thank you!
-Paul
PG01
Up here to the right
Dont think so.... pull the lock button off the door panel and then grab rod and try to unlock it that way.
dotwell69
