Bose trouble. please help.
roc0511
Hello,
I have an 03 Yukon xl denali. I installed a pioneer dvd headunit with the interface and ipod connect. Everything has been working fine for a while. I know have an issue. The left front channel speakers keeping cutting out. However when I turn the fade all the way to the front and turn the balance all the way to the left and crank the volume up I starts to work again. Is this a bose amp issue ? Or a speaker issue? Please help its driving me crazy.
yates ™
Resident Apple hater
Iowa
I would say an amp issue. You could just eliminate the amp and run the speakers off the deck.
TnTahoe
TN
I have heard of those interfaces going bad, so you might want to check that out as well
R
roc0511
I have thought of that as well and I think I will contact the company and see what they have to say.
---------- Post added at 11:38 AM ---------- Previous post was at 11:35 AM ----------
I would say an amp issue. You could just eliminate the amp and run the speakers off the deck.[/QUOTE
How would I go about doing that? would I need to run all new speaker wire as I am sure the bose wire on ties into the bose amp. Also would I lose my factory sub doing that? This bose stuff is driving me up a wall. I WANT THE 90's BACK!!!!
yates ™
Iowa
Either run new wires or use jumper wires to bypass the amp, this would be done at the amp. I am not sure if you would run into impedance issues though.
mharders
Just outside of Seattle
Yes, I think it might be the amp. When I turn it up Loud the drivers side speaker cuts in and out until I turn it down then it will work consistently. I'm using the same harness as you from BB.
brielmo
