Big Poppa Pump
Do I need blue Loctite when replacing my drive belt tensioner and idler pulley? This will be the third time I've changed the idler pulley I'm at 172,500 miles. I did not use it the prior two times.
I dont generally use any locktite on any of those. However if your having issues with the pulleys which type are you buying? You might have to hunt around but i try to stay away from any type using plastic pulleys. Alot of parts stores either only carry the plastic type or you have to ask for them to find the metal type.
