Blown oil cooler lines?
95escahoe
So today went to leave work, fired my truck up backed up and noticed it was leaking a trail and my oil pressure went to 0 (wasn't making and weird sounds yet) and looks like one of the oil cooler lines blew, less then a month old AC Delco lines, gonna get it towed and looked at, so besides the lines there anything else it could be, the front diff is covered in oil nothing any farther back then that, any other things it could be? No leaks or oil loss before this, ran mint
Sent from my HTC One X using Tapatalk
newbie78
I think I might have the same thing. I will take a picture tomorrow I'm doing some work on the truck. It could be coming from the oil filter adapter gasket or even the oil pan gasket.
95escahoe
95escahoe
I was thinking maybe the oil pan gasket too, it had a slight leak awhile ago tightend the pan a lil and has been good since been a year or so
95escahoe
95escahoe
inspect the fittings on the radiator for the cooler lines for leakage as well and anything that may have damaged the line.
They look fine, and can't see anything that would have damaged it, looked underneath couldn't really see anything besides the front diff being soaked in oil
SunlitComet
OBS Jedi-Do Good
unknown at this time.
well when the hoses are replaced look at the old ones. are they broken in the rubber part or metal lines or at the crimp joints?
95escahoe
95escahoe
Update: one of the lines was not seated correctly and came out
MrRuiz
