Block heater
Padraig
This is likely silly but I can not figure out where the cord for the block heater plugs in?
Thanks,
Padraig
StephenPT
St. Helens, OR
Drivers side, lower area of the bumper is two plastic covers with little notches in them to pry them open. One is block heater and the other is tow hook.
P
Padraig
OK...found it. WOW.....Could they have found a more inconvenient location? I am so looking forward to kneeling in the snow to remove and replace door and plug in cord.
Padraig
UsualSuspect
SoCal
Padraig
Wait until you drive a 2500HD or 3500HD. The plug for those are on the lower plastic piece under the bumper. It has does have a spring loaded door that will close automatically, but it's still low to the ground.
Stbentoak
There is no logical reason this vehicle NEEDS to be plugged in, unless it's going to be -20 for days.... with 0W-20, thick oil isn't an issue, and it warms up faster than any vehicle I've owned....
P
Padraig
Well, I do live in Western NY snow belt, LOL
Padraig
Vladimir2306
Even -30 does not cause any problems. There is another question; cold starting the engine itself is quite harmful to it. And connecting to a heater solves several problems at once. The engine starts already warm, the cabin immediately becomes warm, and it is possible to warm up the car in a closed garage. My father had a Ford Explorer with a standard electric engine heater. In winter, my father plugged it into an outlet that was activated at home an hour before leaving, and got into a warm car, which was parked in a closed garage. Is this necessary? no, but damn convenient)
Laurents10
