better ride??djm 3" LCA or Belltech 2" drop spindle
Denalilover
CT
Already dropped on 2/3 belltech kit, but want to go lower, ive heard the djm 3" LCA have a better ride is this true..and can i just take out my spacer to drop the rear to 4"..to make it even out or do i need the 5" springs
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Arms will replace the bushings
Arms will replace the balljoints
Arms wont lose turning radius
Arms are adjustable 2-3 inches
Arms have better balljoint angle
Arms will tuck front tires better
I would do arms along with the belltech sp shocks. $445 shipped and ive done many over the past 16 years
krt
So Cal
Is $445 with just the lower arms Tony?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
445 is lower arms plus the belltech sp shocks
quest51210
Do you need to have factory keys to do LCA? I have the Groundforce ones on there and didn't want to deal with getting new ones unless someone was throwing theirs away on here
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
you will need to crank it up all the way
quest51210
Well that works for me, you're about to get a major order when vw buys back this Passat lol
Denalilover
Denalilover
CT
Tony im going to order that Lca this week...im going to get New bumpstops for the front,should i get Denali again or z71
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
New bumps tops not needed djm has different design
I thought our torsion bar suspension needs bumpstops in order to work properly. What's different with the DJM arms?
Ihaveatahoetoo
