Thank for all the comments!!!
As for sub plans, I'm not sure on what I'll be doing. I use my third row
seating way too often to be yanking a big sub box in and out.
Been thinking about seeing what can be fit into the rear wheel well area
where the jack is.
The main goal though with the RAAMmat and ensolite is just to make it a
quieter ride for those long trips.
As for how to do the headlights, I followed a how-to I read a long time ago
over on tahoeforum.com. It's pretty straight forward though.
-Preheat oven to 180
-Bake headlight for 10 minutes the first time
-Take out headlight and start prying it apart at the seam.
(It's tough to get started but once you get a little bit
going you can just pull it apart with your hands)
-Put it back in the oven after a minute minutes of
trying to seperate the lense to keep the adhesive soft,
but only for about five minutes this time.
-Repeat until you have it apart (took me 4 times in the oven)
-Once apart, there are a few screws to take out and then just
pop out the orange lense and the turn singnal lense.
-Paint as desired.
-Reassemble in reverse order.
Hit me up if you need help when doing it and I'll try to give some
advice on little things I came across.
I used an etching primer followed by SEM exterior trim paint (both
in rattle can form).
I just bought some G4's off of Denali132 and they should be here
on Monday, I can't wait to get them on.
It's coming together slowly!
