Auto-ride PSI adjustment
STORMIN08
Does any one know the psi of the stock system or if it is even possible to adjust it ?
My thought is this, in a since of leveling, the psi increases to a hieve shutoff by level limit rod...so if i were to adjust slightly, would it in turn apply slightly lower psi ?
The more i drive this thing (2013 ltz burb), the more i dislike the 20" wheel and autoride combo.
I also did some reading, and didnt realize how much the tow /haul affected th ride as well. And i use tow/haul al the time to aid in the shift schedule, so a tune will be ordered to correct that issue.
the blur
Cyber Space
I own both trucks. With auto-ride & without. The without autoride is much better, much smoother. and is more user friendly, if you want to go after market struts. autoride, your basically stuck with autoride.
STORMIN08
STORMIN08
Well, i think i am going to try shorter length rods...not much, but even a honest 3/16" will have some variable in how much psi is required to keep level.
I dont want to rid the truck of the auto ride, but i would like a 22" wheel AND a good ride.
