Air Ride Bypass Help
whtailhunter319
I have a 07 Tahoe LTZ. Ive already converted to standard suspension with resistors. However im still getting a CHECK SUSPENSION message. I pulled codes and its for the compressor C0660. I would like to just disable the entire system if possible. I did some digging on this and found a "power down sequence" procedure "disconnect neg terminal, pull RTD fuse, reconnect neg" which i attempted but there is no RTD fuse. Can someone offer any other advice on how to convince the BCM air ride isnt there anymore??
camaroz2887
Nj
Should b larger than a normal fuse I believe and also 30 amp. I remember something about an alc fuse but don’t recall exactly.
Also some people have had problems disconnecting the battery cable pulling the fuse and reattaching the battery cable too soon.
Luggz
