AFM stuck in 4cyl
MrJP
Alabama
A very good friend has an 2011, I think, Tahoe that is currently stuck in 4cyl mode. They are quoting her just over 2 grand at the dealership. Saying there is internal engine work and it takes days. Is there a way of disabling this or testing it. I don't trust this dealer. They have a rep for taking advantage of people, particularly young ladies.
ISU-152
So don't let her take it there. Start with disconnecting the negative battery cable for 10 mins
ta07hoe
you gotta pull timing cover and heads, it's a lot of work. I'd junk the afm valve train, get the block of plate and regular valve train and shut it off on the computer. Look up afm Delet kits
CrashTestDummy
Pearland, Texas
Is it really in 4 cyl mode, or has a lifter(s) already failed, causing it to run like it's in 4 cyl mode. I thought the system 'failed' to 8 cyl mode when things went wrong, not the other way around.
M
MrJP
Alabama
They said 4cyl. I believe it given how weak it is
Sent from my SAMSUNG-SM-N910A using Tapatalk
93blkongreenpro
If the battery disconnect fixes it, I would disable the afm all together. I disabled mine.
Sent from my SM-G935P using Tapatalk
M
MrJP
Alabama
She traded rides. So no longer her problem. Thanks for the advice though
