'99 OBS Suburban with rear A/C, R134A capacity?
me88
Germany
Vehicle in question is a 1999 Suburban LT 5.7 (last of the square old body style) with front & rear AC.
So some time ago the A/C compressor was replaced (due to the typical "belly leak") with a Delphi CS0120 along with a new drier/accumulator, and it was charged to the R134A amount that all service literature says: 4 LBS (1.81 KG). The system was still cooling very well with the old compressor.
The workshop that did the work was not able to replace the orifice tube ("we couldn't get the old one out" :rolleyes:) and the rear expansion valve. Not ideal but I figured since the old compressor still worked perfectly fine and didn't explode, it should be ok.
With the new compressor cooling output has been greatly reduced, at best it'll do around 50°F (10°C) at the outlets when it's close to 90°F (30°C) outside. Air temperature coming out front and back feels about the same. Before it felt like a fridge, now it's kinda so-so. I noticed that the old drier has a sticker on it saying that it should be charged with 3 LBS 8 OZ (1.588 KG), which is interesting because that contradicts with the GM manual and all info on the internet.
The fan clutch is new and engages in hot weather when sitting in traffic, so that operates as it should.
Any opinions on why it has such weak AC performance?
exp500
Oriface tube partially plugged or undercharged.
Sometimes, on these old ones they wind up overfilled with oil due to poor servicing or carelessness when flushing.This usually creates a slugging where oil fills the low spots in the line rather than a film. With the reduced capacity in the system the charge acts funny, borderline hi pressures. I hope my description is understandable to you. Still drinking 1st cup of coffee. Good Luck and keep posting results.
M
me88
Germany
The shop did not flush the system since there was no reason to do that, they only swapped out the compressor. I hope they put the correct amount of oil in it, the compressor shipped with oil pre-filled.
Do you know what the deal is with the two different capacities for the same version?
Shop just says it cools, what else do you want :rolleyes:
exp500
Some other tests are - rear air is excellent, front weak definate Orifice Tube. (1st guess for you is undercharged)
Shooting the temps with IR temp gun helps narrow down problems. Start at compressor discharge and work your way downstream. Both sides of Orifice Tube, receiver/dryer, right on down the line with compressor running.Also shoot air temps f/r . Useful when icing a problem too.
M
me88
Germany
Rear air feels identical to the front air. I'll check the temperatures of the compressor input and output once it's warmer outside again.
OR VietVet
Multnomah Falls
Military
Willamette Valley
That shop is lacking in common sense. The compressor gets changed and the accumulator should be changed too. They make orifice tube repair kits but I hate them. They always leak. Change that evaporator if needed. The system should be flushed, especially if enough crud is in the system that keeps the orifice from being removed. Did that shop say the accumulator should be changed and you said no or did they even mention it?
M
me88
Germany
I brought a new compressor, drier/accumulator, o-rings, orifice tube and expansion valve. The new compressor, the o-rings and drier/accumulator were put in. System was evacuated, held a vacuum and was recharged.
They just told me that they couldn't get the orifice tube out and left the old one in it.
OR VietVet
Multnomah Falls
Military
Willamette Valley
The system takes 4 lbs. R134A or 64 ounces. Does not sound like the system was flushed and those condensers had clogging problems, if I remember right. I could be wrong about the condensers. That orifice needs to be changed or swap out the part it is mounted in. They used to be at the evaporator but I have not dealt with the ones at the condenser.
M
me88
Germany
The system takes 4 lbs. R134A or 64 ounces...
That is the interesting part from the first post. The old drier/accumulator had a sticker on it saying 3 LBS 8 OZ -> 56 OZ, and I can guarantee that no one except the factory has touched that system before.
Why was the spec changed? I think the "newer" spec is wrong, and it's just overcharged now. I have to see if I can get someone to connect gauges to it and see if they indicate an overcharge.
OR VietVet
Multnomah Falls
Military
Willamette Valley
Confucius say, "Dig deep grasshopper and find the answers your heart wishes for".
