9 miles per gallon!!
H
h2100
White Lake, MI
Since you get decent fuel economy when you are not a towing. I was suspect the trailer is the culprit. Does the trailer have surge brakes if so are the adjusted properly?
i'll check this. i can push it around the yard with help from the wife (with no boat/she's not that strong!)
Bigkevschopshop
Northside H-Town
Get your RPO codes from your glovebox and post the photo here, it really sounds like you have a 3.08 rear gear, if so that could be part of the issue. Do you use tow haul button and lock it in 4th or 5th gear on the trans?
tom3
When you're towing do you see the AFM dropping cylinders on easy cruise? Not sure how this works in tow mode.
dnbri512
