880 LED fog lights
corvette744
2004 Z-71
Northern illinois
Can't tell by looking at it dead on. How's the output on the road ?
Or is that what youre talking about ? How bright it is in the housing.
Both-Not much diff than stock output on the road-depressing all that work and 100 bucks for the ballast and bulbs and you get junk-getting ahold of this company is worse than the last company i had problems with.
05Single
afraid of the dark
The housings are crap to begin with. I'll never know why they make round fog housings. Maybe try out hids.
02Greenz71
Ok drove me crazy all day at work waiting to get home and change the bulb facing the right way-took them out fixed it reinstalled and almost exactly the same bummer.I love their low beams but the high beams and fog lights suck.before pic
Are those the stock headlight housings? I've been wanting to upgrade my headlights and fogs. I'm glad you posted this because I was going for the exact set up, using the opt7's. Do you ever get flashed, are you blinding oncoming traffic?
So would you only recommend going with the low beam? And how hard were the low beams to install? Did you have to modify anything? I'm really wanting to drop the ball and order a set of only for the low beams.
corvette744
2004 Z-71
Northern illinois
I love the low beams dont get flashed at all and are perfect light-the fan motors are pretty loud but you wont notice them after a week.Very easy to install about 5 minutes no mods on low or high but fog lights massive mods to get to fit.I would not recommend the high or fog lights my opinion they suck badly-and mine are aimed perfectly with new headlight housings.
02Greenz71
Thanks man. After reading like I said you saved me a couple hundred bucks. I was planning on using opt7 on lows, highs, and fogs. Now I'll just go with the low beams. I kinda wanted to upgrade to some Depot projectors and try the flux beam x bulbs, but after reading this I believe I'll just stick with low beams in the stock housing for now. Thank you for giving us a heads up!
agmanw8n
