6 inch lowering springs
lx4life
Hey Houston u plan on selling the trailblazer ss springs?
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
Looks good HoustonJG!! And good job Tony! I wonder if a Tahoe/Yukon would sit any lower than an Avy with this setup?
HoustonJG, do you have pics of your bumpstop removal/replacement?
HoustonJG
Iwaslowr,
I don't have a pic of the free travel mod
But I just cut the bracket off then I drilled and tapped a hole for the low profile bump stop
I pull a 16' enclosed trailer with my truck and I have only bottomed out once since I lowered it and cut the bracket off.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
i will need the springs back to go over final specs ill tell you when i need them back.
a avalanche sits about 1/2 to 9/16 of a inch higher than a tahoe in the rear. with that tire size you should be in 32 inch range about.
HoustonJG
Yes the avalanches do sit up high from the factory
Just email me when you need them back
I want a set for sure when they are under production
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
no problem i need to work a few things out to get these done. this will fit all the 00-13 tahoes no problem
---------- Post added at 08:33 PM ---------- Previous post was at 08:22 PM ----------
also I will be measuring the springs when I get them back and will set up the correct number if people want to run helper bags.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
i would like to send your springs to a guy with a 00-06 truck with the djm hardware kit/belltech shocks.
Anyone here that can help me out
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
houston send you pm also I would need the springs back ill pay for shipping i need to test on a 00-06 truck.
HK-DEMON-
Stockton CA
Tony, are the spring in production the same diameter as the DJM springs? Also, are these spring still in production or are they ready for purchase?
I would be interested in a set if the ride quality is much better than the old DJM springs.
Jamesj82
