5.3 build ideas input please
Trey Hardy
Eastern North Carolina
I’m aiming towards 500+ hp with this build I’m wondering if the botttom end needs addressing while I have the motor out?
(Stroker kit?) (forged rods and pistons?)
It’s a 5.3 out a 07 avalanche with 160,000 on her.
I planned to dod delete it along with a stage 4 cam and built top end.
Planning to port polish deck and valve job the 243 heads that are on it
Another question is that I plan on doing a lsa supercharger down the road but it’ll probably be another year before I ever get to that… so should I be looking at supercharger cams vs the stage 4?
I’ll be putting a 3400-3600 stall in the trans when I swap the motor and I’ll build the 4l60 out the avalanche to have for when my stock one ***** the bed
Looking at cam motion and Texas speed stuff
If there is a fairly simple and cost efficient turbo kit that’s cheaper then a lsa swap I’ve looked into the speed engineering twin turbo kit…
I’m just spit balling ideas and getting game plan together before I start ordering parts
@randeez @Tonyrodz i know yall have boosted setups do yall have a build sheet on y’all’s motor setup on y’all’s build thread by chance? Are you guys happy with the setup? Randy you got a pro charger correct? And Tony’s got the Whipple?
randeez
south florida
to get 500hp out of a 5.3 NA isnt going to be great for boost later on down the road.
meaning compression will have to be 13:1 and youll have to spin it to 9k.
the money spent to get there would have already bought sc/turbo.
Trey Hardy
Trey Hardy
I’ve got to tear it down for the dod delete anyways I just diddnt want to double work or spend twice as much having to change parts down the road to accommodate for boost
I have been looking at the chopacabra tsp cam and the bald eagle tsp cam but i get my build sheet in order id rather opt for a custom grind cam specifically for my setup/build
I had great gains with my previous build which was stock 5.3 bottom end with ported polished milled and valve job 243s with springs pushrods and all new seals matched with the Longtubes and ported throttle body the truck would really get down for how big it was
strutaeng
Dallas, Texas
Umm...if forced induction is on the future plans, just gap the rings and probably new cam/rod/main bearings.
Or are you aiming for 500 HP NA, then forced induction after that? What levels are you thinking after the forced induction? If much higher than 500 HP, then maybe forged pistons are a good idea now? But I'm pretty sure plenty of guys run superchargers with stock bottom end w/o any issues.
If forced induction is ultimate goal, then no stroker kit. Stroker would be a good option is you are staying NA. Ay least that's what I do for those power goals.
IDK about cam selection though.
randeez
south florida
yea im def not trying to discourage you lol
just mean a lot of the money spent now you could prob boost it and get same results with more potential
i would do a compression and leak down test on the bottom end, if everything looks healthy i would just leave it.
heads, no doubt there are benefits to port/polish or cnc but cost to work them over, especially if going boosted when you can just turn it up another psi or two. good springs and trunion kit tho either way
definitely dod delete and cam swap, but at this point you need to decide which way to go. big NA cam, turbo/centrifugal, or positive displacement (lsa/whipple). boost cam in NA prob only going to give up 30-40hp. any of them is way better than stock
Trey Hardy
Trey Hardy
Or are you aiming for 500 HP NA, then forced induction after that? What levels are you thinking after the forced induction? If much higher than 500 HP, then maybe forged pistons are a good idea now? But I'm pretty plenty of guys run superchargers with stock bottom end w/o any issues.
I was aiming around or close to 400 n/a and after the lsa supercharger or turbo it would probably be around the 500-600hp range I would imagine depending on how much boost I decide to run. Again the boost will be later on but I’d like to get whatever I need for the motor and have it setup to where I don’t have to tear back into it once I get it installed
Trey Hardy
Trey Hardy
Jesus lsa swaps have went out of sight! When I first looked into them you could do them for around 2500-3500$ now there almost double that! wtf?!
So these are my 3 options on boost within my budget
Last heads I had worked up ran me I think 400$ which is a lot cheaper then Texas speeds 1800$ for cnc work and cam kit
So hopefully with the required stuff for the dod delete cam bolts gaskets etc along with machine work on the heads I’m hoping to be around the 1500-2000$ range
God even thinking about the money I’ll be spending on this motor alone has me wondering if I’ve completely lost my cookies beings I only paid 5000$ for the thing 2-3 years ago…
Geotrash
Dave
Richmond, VA
If it were me, I'd lean toward the Maggie. Fewer trade-offs in terms of serviceability, and you won't be pulling in air over the exhaust manifold. Plus they have a good rep for reliability. The twin turbos look like a nightmare for serviceability later on.
Trey Hardy
Trey Hardy
That’s what I was thinking also I don’t want a lot of added maintenance or fabrication work to get it installed
So what would I need with the magnason kit I posted? Just the pully belt and supporting fuel system? Injectors and fuel pump?
Geotrash
Dave
Richmond, VA
So what would I need with the magnason kit I posted? Just the pully belt and supporting fuel system? Injector and pump?
I haven't run a supercharger yet on one of these so I don't know off the top of my head. But Magnuson will have all of that info for you. I'd give Texas Speed a call and see what they say.
agmanw8n
