J444HN
- Joined
- Oct 20, 2013
- Posts
- 42
- Reaction score
- 2
Hi guys, I'm hoping someone can help.
I live in the UK and after my trans blowing I bought a rebuilt 4l60e online from a guy who builds them all the time apparently.
Anyway, for various reasons I can't return it or contact him for that matter and the transmission isn't working as it should.
I'll list the problems and let you see what I'm dealing with.
When selecting drive or reverse it takes a second or two to 'grab' and almost thumps into gear. Then it's fine...til you select either Reverse or Drive again and it does it again.
The main issue is it doesn't shift properly. It holds gears too long and downshifts at strange points...more worryingly, it rarely shifts into 4th and just holds 3rd in high revs.
Here is the list of the parts used and whether you believe them to be part of the problem;
"Currently has a 4wd output shaft fitted, but I am happy to fit a 2wd one and tail housing at no extra cost. There will be a slight delay in dispatch we hope I swap it over if required.
It has all Alto HEG frictions
Alto red band,
Corvette servo,
extra frictions in the 3-4 clutch pack,
Transgo HD2 shift kit,
all new seals etc throughout. Reconditioned pump, new solenoids and selector shaft switch.
Basically a full heavy duty/high performance rebuild, good for up to around 400hp or heavy towing. Pictures show some of the parts that went into the transmission"
That's the description from the seller, any help or thoughts would be much appreciated.
John
Alto red band,
Corvette servo,
John
