3" Lift with 18x10 Moto
dubfreaks
Philly
What's the best size tire for this setup on an 03 Z71 Tahoe. Don't wanna go too big, if you have experience with this setup what size tire do you recommend
CamReynolds
i run a 285 width, 33 inch tall toyo rt. i have a leveling kit. they are just inside the wheel wells so no tire is sticking out. toyo rt and mt are great
dubfreaks
dubfreaks
Philly
Thanks.. You think if I went with a 17" wheel it would make much difference to where I could go 35s?
SRTH8R
Littleton, CO
Smaller wheel won't make the tire shrink. Get a real 6 inch lift if you want to run 35's.
M1Gunner
Gainesville, Fl
When I had a just a straight 6in suspension lift I ran 35 1250 18 Toyo MT's on Moto 957's and that setup only rubbed just barely when turning the wheel to full lock to the left.
So you'll have to run at least a 6in lift to run 35's
Either way I'd go with Toyo hands down. Every other set of tires ive run, they don't compare to mud traction or ride comfort and sound.
osiris94ej
Casper Wyoming
18x10 -24 offset. 275/65r18 (32x11) on level only, stock rear. Still rubbed the washer tank when turned right and I trimmed as much as I could. If you are wanting to go any bigger with tire the width and low offset are what's going to make the fitment more difficult. This same wheel/suspension setup rubbed with a 285/60r18 (31x11.5) as well.a25b4cb2171c727196bc134111270a4f.jpg
On the 285's you can see the bottom of the washer res.
Sent from my SM-N920V using Tapatalk
juniordaboi909
