285/50/22
onelovechicago
Anyone running this size (285/50/22)? Thinking with a level and stock offset there shouldnt be any cutting of the wheel well since its only 11.75" compared to the 33x12.5
cjweb11
Houston TX
The 285 tire width will not produce any problems, however the diameter of the tire will likely cause rub on the front of wheel wells at full turn.
I have a Z71 with Truxxx 2.5"F level and BFG 285/65R18 (~32.6") on stock +31 offset. Didn't experience problems from the increase in in width, but had to trim the front inner fenders to eliminate rub due to diameter increase.
The 285/50R22 (~33.2") are slightly larger so I assume trimming will be necessary, even with a level kit.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
I RUN 305 45 22 on them no problems. Hell i lower them on 305 45 22 with no issues
J2PDeweese
