2017 Yukon/Having problems
andrewwest
I need some help, I have a 2017 yukon xl, having issues with the push button start, nothing light up and won't start. Can someone please help
All battery cables good. No corrosion on terminal, could it be a fuse??
battery cables can corrode on the inside, I would use a meter and start checking voltages, if you blew a big fuse it would be one of the ones on top of the battery and those are not visible to check, you need a basic multi meter.
OR VietVet
Multnomah Falls
Military
Willamette Valley
Yes, @Doubeleive asked about battery and cables first and you said "all battery cables good". How did you check them? They corrode where they cannot be seen. Did you inspect/check battery as asked? If is original battery, it is 6 years old. Basics first.
RST Dana
OH
Try putting your fob in the spot in the console. Could be faulty fob or weak battery.
Dlshort21
