2015 Yukon HID Conversion from The Retrofit Source
k5blazerkeith
Not meaning to dredge up an old thread (that has old title), but just adding an update to my earlier post. I bought the HID kit from KBCARSTUFF over a month ago and it works perfect...not one complaint. I bought the Philips 4300 upgrade bulbs, rest of kit is the standard XenonDepot kit, with the Canbus adapters (they act as your capacitors also - confirmed with KBCARSTUFF tech guy). I was afraid to write this (Murphy's Law says that now I'll have an issue!), but given that everything has worked perfectly, I am hopeful they will keep working great for long time. If anything fails I'll come back...
toi
could you put a link here for which kit you are mentioning in this post please.
thank you
toi
RikMN
Quick question did any of you who upgraded need to realign the projectors or notice you get flashed by oncoming traffic?
pro510
Those who used the extreme HID 35w, did you use the relay? I haven't installed yet but plugged one in without the relay and it worked OK.
What have people done about the auto lights - anyone managed to get the DRL harness from gen5diy to work with HID?
Thanks
Sent from my SM-G900P using Tapatalk
LGSONE
RikMN, I've always checked after putting in HID's, measured and adjusted as needed. With these truck sitting up a bit higher I try to be respectful of others... We have all seen the dumbass who didn't and it is annoying AND a waste of the investment if the light isn't hitting the road where it is needed.
LGSONE
toi
Did you use the coupon code?
i havent bought it yet.
this kit in the link doesnt mention anything like canbus and such.i am not even sure if i need those things yet.
but this might be the kit to buy.
we will see
pro510
we will see
Xenondepot.com is the same company and has the canbus option shown.
  • Like
Reactions: toi
