2015 Tahoe Brake Squeak?
Discussion in 'Exterior' started by Bighurk, May 15, 2018.
  1. Bighurk
    Bighurk Member
    44
    Jun 1, 2015
    Name:
    hercules
    It is only doing it while driving. As soon as I start to brake, it goes away.
    Edit: this is only happening on the passenger side
  2. dbbd1
    dbbd1 Full Access Member
    569
    182
    May 12, 2017
    Name:
    David
    Not sure why this would matter but, when you jack it up to take off the tire, jack it by the control arm not by the frame. This will make sure that there is weight on that part of the suspension not having it just hang there. Maybe it will make a difference???
  3. Tahoe14
    Tahoe14 Full Access Member
    567
    133
    Jun 10, 2014
    Central Fl
    Name:
    Gary
    Maybe your rotor is warped.
  4. dbbd1
    569
    182
    May 12, 2017
    Name:
    David
    Yeah, that's what I was thinking but they couldn't duplicate the problem with the tire off. That's why I suggested making sure that there was some weight on the suspension. Just for S and G's.
  5. dbbd1
    569
    182
    May 12, 2017
    Name:
    David
    Actually, you could try swapping rotors, see if the problem moves.
    Normally, I would not recommend that at all. But, since they were not re-surfaced or new and the pads themselves are fairly new, it couldn't hurt.
  6. Bighurk
    Bighurk Member
    44
    Jun 1, 2015
    Name:
    hercules
    That’s interesting, how often do people change the rotors? Also l if that is the case then I will have to swap them out and see if it makes a difference.
    Thanks!
  7. dbbd1
    569
    182
    May 12, 2017
    Name:
    David
    You should re-surface or replace at every pad change. There is a certain spec of rotor thickness that you should replace instead of re-surface. I usually just replace each time. For the expense and time that the vehicle is down (usually only a day or so but...).
  8. Doubeleive
    Doubeleive Elite Member Supporting Member
    2,021
    1,100
    Name:
    my money is on the bent clip....
  9. hound_dog
    hound_dog TYF Newbie
    22
    Apr 9, 2015
    Name:
    Ryan
    I had a grinding, pulsing feel and sound on the rear brakes and replaced the rotors (both new AC Delco for under $50 each shipped) and that solved the sound and feel. It didn't take too long to do and I really should have done it 15k miles ago when I changed the pads. From now on, I'm going to only replace pads and rotors at the same time...not worth the hassle.
  10. Bighurk
    Bighurk Member
    44
    Jun 1, 2015
    Name:
    hercules
    Yeah and that’s what I am going to do as well. I just didn’t think of that because the rear is hardly ever used.
Share This Page
