2013 new owner towing report
cycho
Ok it's been a few months, 2500 miles and a few trips to the Northland...
I have a GMC Sierra extended cab 4.8 (purchased new, now at ~168k miles) and this 2013 Tahoe 4X4 LTZ 5.3 with 73K on the clock.This thing is a beast! It's takes a bit to get used to but overall I should have bought a Tahoe a long time ago. In fact I still kick myself for not buying a Blazer when I bought my first new vehicle in 1978. That's when I bought a 4X4 short bed Chevy. Really enjoyed that truck but with three kids at the time, a Blazer would have been a better choice.
I don't drive the Tahoe much because we trying to keep the mileage low. We are retiring next year and it's intended to be our last vehicle. We make bimonthly trips to our retirement home which is 150 miles up into the Ponderosa Pines (on the rim as they say in AZ). There are two stretches of highway with several 6% & 7% grades to climb both ways. The longest 6% being 5 miles, the longest 7% being 3 miles. These give the Tahoe problems when towing my 20 foot enclosed trailer.
The trailer weighs about 2800 lbs dry. I figure we were pushing 4000lbs on the way up and empty coming come. Going up was at night so still about 100° in the beginning down to 65° for the last hill. Coming home was late afternoon. Most of the hilly terrain was run in the low 100° temperature. Coming into Phoenix it was 109°.
On the way up the Tahoe coolant temperature reached 235° while the trans temp reached 225° on the steepest portion of the highway. On the way home the coolant once again reached 235° but the trans temp got to 235° on the long 7% grade. This was running about 3K rpm in 2nd gear (i had more pedal but was afraid it would over heat more) . The Tahoe doesn't have an external trans cooler but this is very disappointing just the same. My old GMC pick up out pulls the Tahoe and never overheats! Both have high gear ratios.
Once in Phoenix at 60 - 65 mph on the freeway the trans temp ran 215° to 220° the rest of the way home. Out side temp was a steady 109°. Is this just too much trailer for a high geared 5.3 Tahoe in this AZ heat? By itself or pulling an 8 enclosed trailer the Hoe is awesome!
I just bought a TRU COOL MAX trans cooler but at 108 to 113 everyday it will be a while until I tackle the install. At this point I'm not sure if the transmission itself is over heating or if it's the engine coolant/radiator heating up the trans oil?
Edited Trans temps + 100°
intheburbs
SE MI
So, let me get this straight, you're worried about your transmission getting up to 135°? Are you talking Fahrenheit or Celsius? I'm honestly very skeptical that your transmission stayed below 135°F in 100-degree heat pulling a 4,000-lb trailer with no trans cooler. Are you sure the previous owner didn't install an aftermarket cooler? These trucks are designed to have the transmission running at 180-190° F. My Suburban, with the factory trans cooler, generally runs 100° hotter than the outside temperature when I'm NOT towing. I see no way your transmission stayed that cool without an external cooler.
CrashTestDummy
Pearland, Texas
Yeah, 135-deg F is not that bad. I'd be MUCH more concerned with the 235-deg F coolant temps. Any were you running in second? No wonder the engine got so hot.
St. Louis
Those trans temps seem low, especially while towing. What are they normally when not towing?
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
gpracer1
Phoenix
Something is not right. Either the trans temp sensor is bad or you are talking C.
I’m in Phoenix also and with an LTZ with all the options including K5L cooling package with external trans cooler and 3.42 rear end and my trans temps are 185-195 NOT towing in the Phoenix heat at around 110 degrees. With a 21 ft 4000lbs of boat I’m about 200 degrees on the highway.
Up to the rim is more extreme for sure. I tow a 7000 lb 10ft high travel trailer and there are some beast mountains for sure. I wouldn’t do it with my Tahoe unless I had to. I did it with my heavily modded 99 Tahoe and it was at its limit but only for 1 year till I got the 2000 F350 CC Dually 7.3 with mods.
cycho
cycho
It's time to change your fluids. The radiator coolant is good for 5 years or 150K, whichever comes first, well, time came first in your case. The transmission and fluid can take the higher temps but the fluid still breaks down, wears out, faster. Change it every 36K miles or sooner with the towing you're doing.
When you put clean fluid in those differentials and transfer case, she's going to run even smoother, watch! 3.08 or 3.42 gears? Single speed transfer case?
cycho
cycho
Hi/Low transfer case, 3.08 gears
That's a new one for me to see, a 2-speed TC with 3.08s, interesting. I think it was in 2010 that they started pairing the MP3010s with 3.08 gears and the MP3023s with 3.42s, which was the original setup in 2009.
cycho
cycho
I'll check the gearing again tomorrow, but the 2 speed TC was a big reason for my purchase.
Dev00
