2011 Suburban outside temperature not reading correctly
njracer
Battery was dying over the course of a few days and it finally died the other day. Tossed a battery charger on, put it to start and started up the truck. AC was blowing heat while set to 67 degrees and I noticed the outside temperature reading 55 degrees on the dash (was 90 outside). Disconnected the battery and was able to get the AC to run.
However, the dash is still reading 55 degrees.
I tried the search function but couldn't find anything.
If this is just a matter of replacing the ambient temp sensor, great. The few vids I've seen require you to remove the bumper cover. Any work around for this?
Thanks!
Brian
BTW, new battery was put in this morning and the temp is still reading 55 degrees.
St. Louis
There is an instant update procedure that might help, otherwise if you know someone with a Tech2 they can initialize a relearn or calibration.
The instant update involves holding the recirculate and AC snowflake buttons on the HVAC control at the same time for a couple seconds
If you do have to remove the grill to replace the sensor, it is rather easy and only takes about 2 minutes.
njracer
njracer
The instant update procedure worked!
Thanks!
Luggz
