2011 Denali hybrid wont start
apdyno
I must be searching the wrong way because I haven't been able to locate anything on this issue here. Anyway, I took my wife's car yesterday to get the oil changed and give it a bath. I had no problems right away but 3 hours later it wouldn't start for her. I jumped in and it didn't want to start for me either. I started moving things (power tilt) then it started. She drove home with the check engine light on and didn't think much of it. Next morning, nothing, no lights, bells tilt wont move, nothing. Simple enough right, change the 12 volt battery. Did that, now everything lights up, adjusts as it should but the motor still wont try to start.
So, I had a buddy bring his scanner over and there were 8 different codes, I wrote them down then cleared them. 1 code comes back as soon as the clear function is complete. Code P0C76 just keeps coming back. Is there anything I can do to get the vehicle to start so I can drive it the dealership and get it fixed correctly? This code is related to the hybrid system, luckily it should still be covered under warranty. 8 years/100,000 miles on hybrid components, correct? Any help or suggestions would be great.
Thanks
soulsea
Administrator
Bar
One thing you may want to do is lift the 2nd row seat up and make sure all the harnesses are plugged in correctly (pass side). A lot of times service departments will unplug them as a safety measure when servicing the car and they don't plug them back all the way in.
If that's not it then you're going to have to have it towed back to the dealership.
Also stop clearing the codes.
A
apdyno
They didn't touch anything under the seats, I'm sure of that. Kids seats and I was there. The information center does say "service hybrid system" also.
fafafyfy
