2008 Tahoe Hybrid AFM rebuild?
B
BG1988
You need to remember what is happening when the engine switches from V8 to V4 and back.
The VLOM puts oil pressure to the lifter to pressurize or extend the lifter so it engages the pushrod when the cam lifts the lifter. When the VLOM is told to shift to V4, it removes oil pressure to the lifters and and let’s them float while not moving the push rod. The problem with AFM is when the motor goes to shift back to V8 mode. If the pressurization of the lifter is off, the timing of getting the lifter extended by the time the cam lobe comes around is off and can damage the lifter. If your bolts on the VLOM are loose, that means you may have a less than optimal timing on pressurization if the gaskets between the solenoid and the block leak.
Guys put the AFM disablers in to keep the lifters pressurized all the time and reduce the risk of the timing being off when that switch happens and shelling out a lifter and the cam.
that is what M4 does as the disabler
it's only V8 in M4 my running PSI is about 55-60PSI while driving and normal rpms 1500rpm so there is plenty of pressure.. i know your guys tahoe does not have the HIGH pressure variable corvette oil pump
only drive gear has V4 mode (at speed) other wise v8 at idle or auto stop
reverse gear is V8
Park is v8
Neutral is v8
M1-m2-m3 and m4 are v8 mode only(with Super E-assist )
revrae
