mikemhp
- Joined
- Aug 20, 2017
- Posts
- 29
- Reaction score
- 3
happy labor day!
my second post in here, thanks for all the previous replies....
little status update-
2004 yukon 2WD, 5.3, SLT 144k miles
had a no crank/no start issue couple weeks ago.
new battery, pulled starter and it tested great, pretty sure it was wiring or electrical related.
i pulled every single fuse to check, turns out the 40A ignition fuse had a tiny crack in the copper circle that i missed on first inspection.... (the little window was dirty on the bottom...)
replaced it and it started up fine for 2 days..
then DEAD BATTERY again. no crank/no start all over again.
NEVER EVEN KNEW I HAD AN AFTERMARKET VIPER ALARM WAY BACK UP INSIDE THE DASH!
never had a remote or any issues in the past- always just used the factory key fob for locking doors and 'beep beep' factory alarm.
so i researched the alarm, it had a valet switch/ignition interrupt function. i pulled the whole brain of it out and started over.
charged battery for 3 hours, checked fuses again, am currently testing it for a parasitic battery drain just in case.
but today after a charge, it fired right up like normal. will check voltage again later this afternoon and in the morning to see if there is any more voltage drop- but if there IS, i am at a loss as to next step........
battery tested at 14V engine on, 12.3 engine off, 12.14 engine off 20 mins later...
fingers crossed, and any insight would be appreciated!!!
