2001 Tahoe Ground Locations -- Can anyone post them up?
Ledesordre
Looking for a list or diagram/chart with the ground locations for an 2001 Tahoe 4WD Non-Z71.
Wanting to make sure my grounds look solid-- thanks (by the way, searched already to no avail!)
Little John
Looking through Prodemand, there is about 10 grounds listed. look for a ring terminal just kind of "there". With a good flashlight and a good thorough look around your should find most of them. They will be surprisingly small, like 14 gauge small.
and in no particular order here the are:
right front of engine
left radiator support bracket
right rear of engine
right front of engine block
left rear of engine
on left front of body mount
upper left kick panel
upper right kick panel
under drivers seat (possibly only in the "full feature seat")
on left frame rail near body mount
on spare tire hoist bracket
on left B pillar
rear corner of right window
right B pillar
keep in mind some of these may not exist because of the way prodemand is set up, some of them may be a real bastard to reach, and some may be behind plastic
hope it helps, :D
ge1176
