2.5 under strut mounting leveling kit
nixxxster
Hello all,
I know that RC makes a 2 inch under strut mounted leveling kit. I saw a 2.5 under strut mounted kit on ebay too. CCM also make a 2.5 kit, but it install on top of the strut. I wanted to use this kit because its easier to install and no cutting. So the question is, is it ok to use a 2.5 under strut mounted leveling kit.
http://www.ebay.com/itm/2-5-Front-L...-1500-/222246124240?fits=Model:Silverado+1500
Thank you
jd08
Jackson, WI
Are you 2wd or 4wd?
NO if you are 4wd because it will hit the cv axle. Stick with the RC kit or the readylift 2.25 kit.
nixxxster
nixxxster
mine is 4x4, Thank you that's want i founded out after more research.
NGAneer
NWGA
I have the Top Gun Customz 2.5 kit. It's 2" under strut with a 0.5" top plate. Had it for over 2 years with no complaints.
skyetheguy93
