INSTALLATION PROCEDURE
Notice: Applying excessive amounts of sealant may prohibit the intake gasket from sealing properly.
Important: The lower intake manifold must be installed and the fasteners tightened while the adhesive is still wet to the touch.
- Apply a 4.0 mm (0.157 inch) patch of adhesive GM P/N 12346141 or equivalent to the cylinder head side of the lower intake manifold gasket at each end.
- Install the lower intake manifold gasket onto the cylinder head. Use the gasket locator pins in order to properly seat the lower intake manifold gasket onto the cylinder head.
NOTICE: Care must be used to apply the correct amount of sealant onto the gaskets. Applying excessive amounts of sealant may prohibit the intake gaskets from sealing properly.
IMPORTANT: All sealing surfaces must be clean, free of oil, dirt, or any other foreign material.
- Apply a 5 mm (0.197 inch) bead of adhesive GM P/N 12346141 or equivalent to the front top of the engine block.
- Extend the adhesive bead 13 mm (0.50 inch) onto the each lower intake manifold gasket.
- Apply a 5 mm (0.197 inch) bead of adhesive GM P/N 12346141 or equivalent to the rear top of the engine block.
- Extend the adhesive bead 13 mm (0.50 inch) onto each lower intake manifold gasket.
- Install the lower intake manifold onto the engine block and the cylinder heads. NOTICE: Refer to Fastener Notice in Service Precautions.
- Apply threadlock GM P/N 12345382 or equivalent to the threads of the lower intake manifold bolts.
NOTICE: Proper lower intake manifold fastener tightening sequence and torque is critical. Always follow the tightening sequence, and torque the intake manifold bolts using the 3 step method. Failing to do so may distort the
crankshaft bearing bore alignment and cause damage to the crankshaft bearings.
- Install the lower intake manifold bolts.
9.1. Tighten the bolts on the first pass in sequence (1-8) to
3 Nm (27 inch lbs.) . 9.2. Tighten the bolts on the second pass in sequence (1-8) to
12 Nm (106 inch lbs.) . 9.3. Tighten the bolts on the final pass in sequence (1-8) to
15 Nm (11 ft. lbs.) .
- Connect the Evaporative Emission (EVAP) canister purge solenoid valve harness.
10.1. Push the elbow inward until the quick connect snaps into place. 10.2. Pull the elbow outward in order to ensure proper connection.
- Install the valve rocker arm covers Refer to Valve Rocker Arm Cover Installation (Right) and Valve Rocker Arm Cover Installation (Left). NOTICE: Refer to Fastener Notice in Service Precautions.
- Install the power steering bracket using the following procedure:
- Install the power steering bracket onto the stud.
- Install the nut onto the stud finger tight.
- Install the three bolts finger tight.
- Install the two nuts to the back of the power steering pump.
- Tighten the nuts and the bolts to 41 Nm (30 ft. lbs.) .
- Install the power steering pump. Refer to Power Steering Pump Replacement in Steering and Suspension.
- Connect the electrical connector to the power steering pump.
- Connect the fuel pipes to the rear of the intake manifold. Refer to Fuel Hose/Pipes Assembly Replacement (Fuel Pipes Side Tank) in Powertrain Managements.
- Connect the wiring bracket to the rear of the right cylinder head.
- Install the PCV valve.
- Connect the Exhaust Gas Recirculation (EGR) pipe to the bracket and the front of the intake manifold. Refer to Sec Air Injection Check Valve/Pipes Replacement in Powertrain Managements.
- Use a twisting motion to install the vacuum brake booster hose, if equipped.
- Install AIR check valve (crossover) pipe, if equipped. Refer to Sec Air Injection Check Valve/Pipe Replacement in Powertrain Managements.
- Install the Air Conditioning (A/C) compressor onto the power steering bracket.
- Install the A/C compressor bolts.
- Tighten the bolts to 50 Nm (37 ft. lbs.) .
- Install the drive belt. Refer to Drive Belt Replacement.
- Connect the accelerator control cable and the cruise control cable, if equipped. Refer to Accelerator Controls Cable Replacement in Powertrain Managements.
- Install the distributor. Refer to Distributor Replacement.
- Connect all electrical connectors.
- Install the following coolant hoses.
