15+ Belltech Spindles 2wd/4x4 Preorders
2016YUKONSLT
So I would need to swap the front spring back to original design and replace the spindles to get a little more travel? How much travel are we talking? Will it keep the vehicle at the same lowered height?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
If your happy with the ride then leave it alone.
ulakovic22
Lantana, TX
If you are at a 2" drop right now using the cups and you go to a spindle, you will get a 4" drop, so if you don't want to be that low then you will have to touch the spring anyway. Either to put spacers in or to go back to the factory setup. In terms of travel, with your current setup you have decreased the amount of travel before your shock bottoms out and your shock currently rides in an area that it's not designed to. Either stay the way you are if you are happy, or go to a spindle, but unless you want a 4" drop, you can't do both.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
or you can do spindles and take the strut relocators off and put stock spring perch back on
SouthpawSlim
I just bought a 2017 Tahoe premium. It is 4x4. It has autoride. It came on factory 22's. I want to do 24's for the summer but the truck clearly needs a stance adjustment prior to adding wheels because I can stand the factory rake at the moment.
Note I do tow my holiday trailer.
Tony, can you help a a guy out? Also I am located in Canada.
Slim
rattmobbins
Man this is GREAT news!!! The 2 inch drop in the rear of my Escalade is nowhere near enough. 2/5 here I come!!!
ulakovic22
Lantana, TX
Your store currently says non-autoride only on the drops, will that change once you update with the spindle? Looking for your rear kit paired with spindles and sway bars possibly.
Brian12019
