Ok here's my question.
Can you remove the factory air shocks, replace with standard shocks and use the factory comp. to run tbss bags?
Are the air lines the same size?
Can you trick the sensors to keep the truck lower and what kinda drop can be expected by doing this if possible.
Sum up, remove factory air shocks and springs, replace with standard shocks and tbss rear bags..
Thanks for any help.
