06 Tahoe 5.3 - hi and lo oil pressure?
Shibbershabber
Got an odd one here
2006 5.3 with 164k
Oil pressure gauge is pegged xlose to 80 but also getting a 'low oil pressure' warning message too
Drives fine, no ticking
Just the sending unit maybe?
chevymopar
Put a real gauge on it and test it.
I had a 2005 trailblazer i would get that message. Apparently, on that model gauge looked analog but it was a calculation from the pcm based on rpms. Basically a glorified idiot light. Mine would drop to zero and back up. I put a physical guage on it and drove around the pressure was always there. this is a known issue. Maybe the Yukons are the same way?
i'm not a mechanic so don't hate on my description of the scenario.
chevymopar
found my old notes on this below is the most straight forward explanation i saw
GM's description is that the oil pressure is monitored by a 3-way switch
It will signal the PCM @ 0psi, 40psi, & 80psi...all readings in between are calculations made by the PCM using this information and other inputs based on a pre-determined set of conditions programed into the PCM
Ep33401
