Hello all from a newbie!! I have owned a 2004 suburban for about 5 yrs now. I just got done replacing all the brake lines and a rear brake caliper. The problem is I cannot get the brake to pressure up.I have bleed the brakes several times with no luck. I clamped all the rubber hoses at each wheel and the pedal is solid so I think the master cylinder is good. As soon as I unclamp the rear hoses the pedal goes to the floor. I have bleed a quart of fluid through the rear calipers and still no luck! Help!!!
Randy from Pa.
Sent from my SM-G935V using Tapatalk
Randy from Pa.
