titanium02
w7's or bust.
Ever since replacing my battery.. my a/c decided to quit. Wasn't a big deal in November.. but now it's hot.
Under the hood: Compressor kicks on and runs, return lines get ice cold. Took it to a shop and I have good pressure.. not full, but enough.
I've pulled the fuse from inside the car (by driver door on dash) and the delphi relay under the hood. Waited 15 minutes and turned the car/ac on.. Thought I was in luck but then heat started blowing again. The info online said to pull the relay, wait 10, and turn the car on and put a/c on AUTO. I didn't do that.. just waited 15 and tried to push buttons.
The actuator door for the recirc. seems to be working fine.. you can hear the air shift and the mechanical noise of the door.
So.. from here.. I'm going to pull the relay and drive the car for some errands.. then, after the car has been sitting off in a parking lot for a while, I'll put the relay back in and put a/c on AUTO.
I could also check the cabin air filters.. but I really think it's electrical.
30 days before I put the Yukon up for sale.. she digs into my pockets again :|
Thanks brews
Thanks brews
