Abs
02 yukon
Having issues with my 02 yukon, the abs/ brake light is coming on.. the abs don't engage or anything just comes on randomly while driving or when I start it.. any ideas on what could be causing the issue?
Thanks
soulsea
Administrator
Bar
I moved the thread to the correct section for you.
There's a known issue with this generation of ABS controllers where they had "cold" solder joints on the PCB inside the controller housing causing intermittent open circuits. Another common issue is the wheel sensors misreading due to dirt, grease, etc. building up on the sensor tip. These failures are more common in the salted areas for obvious reasons. Until you have someone scan the ABS module for codes, you're gonna be shooting in the dark. So, start first with what you can easily check. Pull the wheels and closely inspect the wheel sensors, harnesses, plugs, etc. Make sure the sensors and reluctor wheels are clean.
jmart157
