Looking to convert to LED headlights and Hi beams
B Hag
Recently replaced all of my interior lights, fog lights, and running lights with LEDs from superbrightleds.com. I also ordered hi beams and headlights but they did not fit the housing properly. Does anyone have suggestions for a place to order LEDs that will ACTUALLY fit the factory housing???
mmeachem
I'm pretty sure there's two types of led kits, one with the fan and another with a cooling element that appears to be more install friendly (VK-5S 9005 H10 9145 8000LM LED Headlight Conversion Kit, High beam headlamp, HID or Halogen Head light Replacement, 6500K Xenon White, 1 Pair https://www.amazon.com/dp/B01FI0S648/ref=cm_sw_r_cp_api_gyXDybSJKFM4M). I've seen both on amazon.
9005 is your Hi Beam
9006 is your Low Beam
DDenali
Orangeburg, SC
Totally off subject but I was wondering since I did a projector retrofit on my 2000 regal lol and I'm wanting to put leds but with it having limited space I'm really looking at the led bulbs with the ribbon heat shield a33ffd0c09a6119080bd3e7717c52b1b.jpg8b2b631b9301f02e497e3974571e3ce6.jpg
Sent from Dugar's iPhone 7 Plus using Tapatalk
Cattivo
The Concrete Jungle
I bought new headlights that have a modified housing so just about any LED bulb will fit in...i used the Lumen LED headlight conversion kit in the new headlights and they are bright as ****!
99-02 Silverado 00-06 Suburban Tahoe Black Headlights+LED Bumper Signal Lamps
Lumen® - LED Headlight Conversion Kit
Bonestock
cmc76
i have the ones linked above with the flexible heat sync. very happy with them. I am going to do high beam as well, mainly for the matching color. i have barely had to use high beams since putting the lows in.
Cattivo
The Concrete Jungle
How is the light output and pattern?
They are very bright! the light pattern covers the entire road ahead of me without blinding oncoming traffic...the trick is to position the LED filament in the correct position or you WILL blind other drivers
I'll take a pic for you tonight on my way home from work
Bonestock
Thanks man I appreciate it!
rddixon
