Lowering and towing??
Yeep740
hello all.
Just picked up a 2016 Yukon Denali SWB 4wd. Was thinking of lowering it a bit. Did some reading and maybe one of NorCal's kits. Question is: how will this effect my towing capabilities? I tow a 5.5k lb boat through out the year and just don't want to mess anything up with lowering the suspension.
Any help is appreciated!
gat0r
DFW
should be fine
depending on how much you lower, you may need a raised hitch
i got a raised 2" hitch for mine & trailer is now level.
Kpwweb
Be sure to adjust the autoride links depending on amount of lowering. Adjust those properly and the rear shocks will air up depending on load to keep the proper height.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
you can tow with my 3.5-4.5 kit or leveling kit. Airlift helper bags work fine with the autoride ive done many
MrLeritz
