6.2 what kind of mpg are you getting?
Deephaven
If I am unlucky I get 11 in town and 18 on the highway. A good day yields 8 towing my boat.
And I say unlucky because it means there is too much traffic to drive like I want to.
powerhaulic
adirondack mts
Back from Daytona towing travel trailer I got in Fla. running 65ish MPH averaged 10.2 trailer weight is appx. 7500#
dre2013
Akron OH
old thread, but fig'd id post anyways. i just bought an 07 esky ext last weekend, love the truck btw-have wanted one for awhile now.
all stock, 92k miles, factory 18's. my current average is right at 13.1mpg after about 300mi, with a lot of idling (its cold here..and havent had remote start for awhile, so i take advantage of it). id say it idles for at least 10min before i go to work, about 25min on lunch break, and 10min before i leave work.
im happy with the mpg with all of the idling. When i drove back from cleveland (30mi) when i bought it, avg was around 18.3 i believe.
powerhaulic
adirondack mts
15k miles since i got my '11
15.2 around town
17.5 highway over 70mph
keep it 65mph or less will do 19++
This is my second full size AWD it is the only way to go
WildernessJeep
Houston, TX
15.2 around town
I say AWD sucks for two reasons: First, you can't turn it off, Secondly, you can't turn it on. I'd far prefer just a regular 4-hi/4-lo transfer case with some auto lockers in the rear axle.
I don't need the AWD when highway driving, and it sucks down fuel and tires unnecessarily. I'd also like to turn it off in parking lots instead of binding the driveline in and out of every parking spot. When I actually do need 4 wheel drive, I always feel like the AWD comes up short. It doesn't split the power evenly between the axles, and it doesn't have a 4-low option. All told, I'd rather the Denali have the standard 4 wheel drive setup.
I recently had my rear axle serviced at a driveline shop and always thought I had some kind of locker in the rear. He says it's just a regular open rear axle, but he also says that most Denali's have an auto locker in the rear. I can hear the brake system activating on slippery surfaces. Is this in lieu of the locker in the rear axle?
Barry822
The noise you hear is your traction control kicking in when you're slipping. Check the RPO codes in your glove box. G80 is the code for the locking rear diff.
Personally I like the AWD. In my caddy I doubt the rear diff would survive very long with over 400ftlb of torque and a 8.5" ring gear.
GMT 900 nut
